MXN 10 Connection Problems
Have just bought a MXN10, but it will not connect to my Network. I have Sky Max WiFi router, UpNp enabled, have tried everything I know, including connecting via ethernet.
When unit is started up, white led flashes, then teal led flashing, unit shows on my iPhone, says it is connected, then teal led goes solid, and unit disappears from iPhone.
Have followed all the set up procedures on the FAQ section etc
I'm sure I'm missing something simple, but cannot figure it out - anybody had similar problems, or can offer a solution? I'm slowly going nuts with this.
Thanks
